Governor linkage, popped spring
Mflen
So I have a John Deere JS48, engine is B&S I believe. One of the springs under the air filter popped off and I can't figure out where it is supposed to attach. I can see the one end because it stayed on. Searched the web everywhere for an image on how it is supposed to look. Any help would be appareciated.
From where the spring is connected trace a line across the number on the carb to the black throttle shaft on the carb. there is a small hole in the black part of that shaft between the number on the carb, and where the silver linkage is connected.
Actually worked on one in the shop earlier today.
