GCV 190 shutting down
jackcu
I have a pressure washer with a Honda motor a GVC 190. After I started runs for about three or four minutes and then shut down. Remove the carburetor, dismantled clean the carburetor cleaned out the fuel tank and cleaned out the fuel lines. Then I cleaned out the fuel cap to make sure it was venting properly and I put it all back together and it's still doing the same thing. Last time I ran it when it started to shut down I unscrewed the fuel cap to check that to make sure it was venting properly the motor still shut down, so I started it again with the fuel cap loose and ran again for about another three minutes and then shut down again. Anybody have any ideas on what's going on with this thing?
SeniorCitizen
I'm thinking there is still a fuel problem for what reason ????.
With the air filter out and a dribbler of gasoline into the carb determine if it will stay alive .
