Gator blades for 34 inch
imoww
HAs anyone replaced the regular blades for the Gator blades ?
The originals blades are raised in the centre. the Gator blades are flat.
Im thinking of putting a washer or 2 in there
I've replace all my regular blades with Gator Blades. Would be nice to know what mower you're talking about. They don't make Gator blades for all mowers.
Mine is ztr34 resi. But here in Australia. We seem to get shafted with parts
I purchased the Gator blades Mrked as gravley 4 inch.... but there must be 2 different types of blades for the Gravley...
You probably wont be able to buy gator Blades for Your mower if it's a residential, there are a lot of residential units that they don't make blades for. If they make them for that particular mower they will be the G3. A lot depends on your spindle shaft size as to what blade you can use. What model Gravely do you have?
