The cylinder filled with gas, it wouldn't crank, so I removed the spark plug and gas poured out.
J jmarches01 Forum Newbie Joined Nov 16, 2019 Threads 1 Messages 1 Nov 16, 2019 / Gas filled cylinder #1 The cylinder filled with gas, it wouldn't crank, so I removed the spark plug and gas poured out.
Russ2251 Well-Known Member Joined Mar 27, 2018 Threads 1 Messages 341 Nov 16, 2019 / Gas filled cylinder #2 Hydrolocked by definition. Perhaps you have a question as to why? Likely a stuck float/needle in carb.
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 271 Messages 6,684 Nov 16, 2019 / Gas filled cylinder #3 Also look for gasoline in the crankcase. And smell on dipstick, change your oil + filter a time or two, gasoline will dilute your oil and bye bye engine.
7394 Lawn Pro Joined Sep 5, 2014 Threads 90 Messages 5,133 Nov 16, 2019 / Gas filled cylinder #4 Definitely change oil & filter a couple times. Crank over the engine w/spark plug removed till it has no more gas is coming out. Just for safety sake, add a gas in-line shut off valve. My old mower had that happen on a 20 hp Briggs. Once was enough for me to add the gas petcock.
