Fuse on craftsman question
Jefft
I have a craftsman 247 288852 rider. I’m changing the selonoid due to no start and notice that one of the wires off the 20 amp fuse is not connected to anything. I don’t see where it goes . Both wires are red if that helps.
I would say that it connects to the same terminal on the solenoid as the wire coming from the battery. Looks like it has been cut. Did it get against the pulley on the tranny or something.
Jefft
Thank you . I’m not sure how it happened but I appreciate your help.
Jeff
