Here in northern ny mostly all the gas stations have a gasoline/ethanol mix [10%] I was told by several guys that do logging up here that the ethanol will make problems for all two stroke and four stroke small engines. Neoprene gaskets will deteriorate and leak, vegetable gaskets will disintegrate.
What to do if this stuff is the only fuel available?
