Fuel coming out of the exhaust of my Kohler OHV engine
Dave1964
  • / Fuel coming out of the exhaust of my Kohler OHV engine
Where do I find the fuel bowl and needle valve to see if it has dirt in it? I have fuel coming out of the exhast
Scrubcadet10
Moderator
Staff member
It's in the carburetor, most likely located on the left side of the engine behind the air filter, follow the fuel line from the fuel tank...
Please post the model and spec numbers of the engine so we can see what particular Kohler engine you have. should be printed on a shiny silver tag on the engine.
Most likely your oil will also be diluted with Gasoline, so drain it and change it, and the filter to. Do NOT run it until you change the oil and filter..
Dave1964
Thank you for the response, It will not crank only floods out.
Model: SPEED ZTR 48,
Product: 966698601
Serial: 032911c001238
