front wheels out of correct alignment
Bobby1966
How do you get front wheels back straight ??? They are both pointing out.
Bwells
Swap them, that should fix it!
There is probably some adjustment nuts on the tie rod.
What mower do you have?
You have come to the wrong forum
You need to be on the Mystic & Physics forum so they can read your mind or find you house in a parallel universe thus find out which one of the 3000 mowers you are having problems with
