Engine Fitting on Scag engine
Zach3713
Hi, I'm new to the forum. I have a 36" scag walkbehind I just picked up. On the engine itself, it has this fitting that i'm not sure what it's purpose is. There is nothing attached to it, and it seems to be spitting out oil. Can anyone tell me what this is? I've attempted to attach a photo, hope it worked.
Can you post the model numbers of that Kaw.
Zach3713
I downloaded the manual, i'm still having a hard time figuring out what this thing is. Can anyone help?
Don't work on Kaws that much, but I'm thinking that your breather hose should be attached there.
EngineMan
I think it is to, if you take a look at the back or side of the air cleaner you should be able to see a outlet there to with or without a pipe on it, if so you need to fit one.
EngineMan
Its the same that is in the manual that I have...!
He needs to look at the air box that will tell him.
Zach3713
He needs to look at the air box that will tell me.
I took some more pics. Let me know if this is what you're looking for.
