First cut of the season with 10590 M-Series
lewb
I bought this mower 2 years ago for 40.00. I had to replace a coil and unplug the bag and oil tank sensor to get it to run. it did have an annoying issue where it would ping kind of like a fouled plug. I messed with idle jet, different spark plug, put on an oem cdi. Same issue, turned out to be a partially plug exhaust port. Since I cleaned the port the mower has been running very smoothly. I still use the injection system. I also have a 10547 so mowing is split between the two. The only real issue with the 10590 is parts are not that easy to find.
My lawn is still dormant, I like to cut it down to 2 inches and bag the grass so the lawn can breath. I then use the clippings in my garden.
jp1961
Nice, I've seen your YouTube vid comparing the two, they both seem to run well.
Regards
Jeff
