All piston engines need crankcase ventilation for two reasons: First, to account for changes in crankcase volume due to piston movement, and second, to provide an escape path for combustion gases that have leaked past the piston rings or exhaust valve guides.
The fewer cylinders an engine has, the more important it is that the crankcase ventilation system be operating properly.
What kind of problem are you having?
