Fh580v throttle adjustment ride on JD mower
Bobg1962
I had to change the head gasket which went fine.
On refitting the throttle and choke assembly I cannot get the throttle to remain on minimum rpm. The bottom govener arm seems to drift up and revs increase.
What am I doing wrong?
I bet a whole lot of stuff. If your engine is like the FJ180V, Kawi has several pages of how to setup the throttle/choke linkage one must follow to a T. If not the linkage will not work proper.
Recommend downloading the manual for YOUR specific engine and read it several times.
