feul mix ratio needed for Yard Machine 25cc string trimmer
suzi_2011
  • / feul mix ratio needed for Yard Machine 25cc string trimmer
I've acquired a used (do't know how old) Yard Machine 25cc string trimmer with no manual.
Does anyone know how much oil I need to put in a gallon of gas for it?
Thanks
Two-Stroke
Welcome to the forum, Suzi.
While I don't know the exact answer to your question, I can say that it's safer to err on the side of adding more oil to the mixture. If you go with 32:1 that would be pretty safe, IMO.
Did you look for a model number on the trimmer? That would be a good thing to have in any case. If you have that you could Google that number and probably find specs for the trimmer -- including the ratio you're looking for.
Briana
Hello & WELCOME to LawnMowerForum.com! :smile:
I have moved your thread to the General Mower Discussion Forum. You'll get a better response there. :thumbsup:
