Repairs Ferris Pro Cut S 61 inch hydraulic fluid leaks over winter.
odrg
For the past two winters the floor is covered with hydraulic fluid. I checked all hoses etc. last spring then filled and looked for leaks. No leaks all summer but over this past winter it leaked out onto the floor again. Any ideas before I check it over again? Used Mobil One 0 grade as recommended.
