I have a Ferris Pro-Cut 61" mower. Currently the engine runs, the blades engage and the deck will hydraulically tilt. However, when you depress the forward and reverse pedal the mower will not move. I lifted the mower into the air and tried to see if the wheels would spin, they did spin, but slowly and you could stop them with your hand.
Does anybody have a suggestion as to what is wrong? Is it the belt, hydraulic motors, hydraulic pump? I do have another Pro-Cut that had an engine fire so I do have a spare pump, and motors.
Any thoughts or suggestions would be greatly appreciated.
