FC290V-CS10
Scrubcadet10
Moderator
Staff member
On my SRX75 mower.... coil went out... not having much luck finding one anywhere. I don't think this JD uses a seperate igniter... i've looked everywhere and haven't found one.
21121-2058 is the coil number.
i can find them for the FC400 etc... they "look" the same but not sure if they'd work or not.
Scrubcadet10
Moderator
Staff member
. sheeeeesh. I'm gonna keep looking..........
Scrubcadet10
Moderator
Staff member
Boy i'm glad you found that one.. i didn't see it on Amazon earlier.
Scrubcadet10
Moderator
Staff member
Saw one on ebay as well
WHAT? I scoured all over both of those places......
hlw49
oh sorry should have looked closer it has been sold
hlw49
There is one on Amazon though for $39.99 plus $1.74 shopping and says in stock.
Scrubcadet10
Moderator
Staff member
got the new coil in. still no spark.
I'll tackle it tomorrow when its less humid
I figure you knew that the coil was bad after testing the coil's resistances so I didn't look up the actual wiring of that engine. But since I have, did you replace the ignitor module [PN 21119-2161]? If not then it is likely to root cause and it should available in aftermarket or you could the universal version that Stens has under PN 440-465. But also make sure the kill circuit isn't grounding out the ignitor when it is not in shut down mode.
Ignitors [electronic triggers] are more prone to be bad than coils. It is the same with coils with built-in ignitors. It just they are not replaceable in those coils.
Kawasaki FC290 Service Manual
PDF page 42 has the resistance checks for the ignition system. Just note the ignitor resistance checks don't cover every failure.
As a side note I had one these ignitors to fail once where it would randomly misfire on compression stroke and when the wasted spark worked nearly sat my pants leg on fire [about a 12" flame thrower] and sounded like my .357 going off.
