Faulty Delois, starter?
jackcu
2007 LT1000. When starting, turn key I hear a clicking noise. After several attempts it will turn over and start. Checked battery 13.02 volts, checked selinoid getting 13.02 into and out of selinoid. So starter or selinoid going out?
Rapid clicking usually indicates bad/dirty/loose battery connections. Check at battery, solenoid and where it grounds on the frame. Or crank in a dark garage, you usually will see sparks.
