EZ-SLIDE
michigan_Rapter sd
anyone else use EZ-SLIDE on their decks - just got the new raptor sd and before turning the blades on did the deck with EZ-SLIDE - I also use it on the snow blower in the winter - slick as cat snot
I never use anything.
I don't even clean under the deck.
Once you get a layer of grass under there. It will get hard and no more grass will stick. And it stops water from rusting the deck.
heavy clay and thick grass here - means grass sticks like a son of a gun. I'm a bit of a yard nut - down to spraying about 6 dandelions a week now on 1 acre . . . working on chickweed too and then will work on clover
