Exmark Lazer Z S Series 60" Kawasaki Shutting Off Issues
GA Fan
Hello,
I have an Exmark Lazer Z S-Series 60" with Kawasaki engine. It has approximately 800hrs on it. I am having issues with the engine shutting off while cutting grass.
It is very odd, intermittently shutting off. It has plenty of fuel, the fuel filter was recently replaced. I have 10 acres of land and it will normally shut down 4-6 times before completion.
When it shuts off, I normally wait about 5 minutes and it will crank back up and run again for about 15 minutes and then shuts off again. Sometimes it will shut off and then after I start it again it will not shut off. It is really weird. When it shuts off, it acts like it is running out of fuel. However, it is normally full or has plenty of fuel in the tank. Any ideas or suggestions? Thanks.
