cruzenmike
Most 42" bagging systems will not have a blower unit; I am not sure on the Ariens/Gravely as they are a 3 blade setup and not 2 like the other 42's. You mentioned getting through a gate which will also require removal of the chute for the bagging system when the fall comes. Also, some mulch kits require use of baffles under the deck that are only meant to be there when using the low-lift mulching blades. Going from mulching to bagging is always going to require to get under the deck no matter what. Ariens/Gravely use steel plates that isolate each blade and will absolutely need to be removed before considering bagging. Toro I think on the SS models show in the videos that you can just plug off the deck to mulch, but I had the recycler kit for my SS4225 and it had different blades and baffles in addition to the plug. Any blade meant to truly "mulch" will not bag well. Yes there are Gators and Copperhead blades that have serrated sails, but those still move way too much air to close off the deck and get a true mulch of grass clippings.
