The engine on my Grasshopper Model 220 w/52" deck has seized up - Kohler CH20 20hp Command. Has anyone gone with other engines than OEM and if so, which brands converted with the least modification? Before I go down a frustrating road would love to learn from others real experiences. Also if I go up in HP from 20 to 23 any problems with that? Thanks in advance for feedback.
just buy a used mower with a good engine, you can find them all the time for around $100 on facebook marketplace, craigslist, or letgo
you can go up in hp with no issues but you NEVER want to go down more then 1 or 2 hp at the most below what the mower came with or the engine may struggle and not cut well in tall grass or even choke out.
briggs or kohler are plug and play swaps but kohlers are wider and if the hood clearance is close with a broken B&S then the kohler wont allow the hood to fit. another note is the directional airflow ring under the hood may not fit but removing them wont cause issues unless your cutting grass in the desert lol
