engine starts but surges chases governor
4scoops
My tractor has sat for several years have put on new carb and cleaned fuel system. Engine starts but surges. Also replaced fuel pump. Any ideas
cruzenmike
Have you replaced the fuel filter and spark plug(s)? If you are surging it is usually from inconsistent fuel delivery into the cylinders, either from fuel leakage inside the carb or elsewhere in the fuel system. Could also be a governor issue, although less likely to spring up after sitting. By chance did you try to start it before you cleaned the fuel system?
