Engine seized
It sounds to me like you may be running your engine a bit too lean. You can richen up the mixture with the two screws on the side of the saw, L for low and idle H for high speed. Probably wouldn't hurt to turn both out at least 1//4 turn counterclockwise, maybe more if the saw still runs all right.
Thanks, will try it.
Sorry to hear about your son's saw. If you get it repaired or you purchase A new saw do not use ethanol based fuel.
The alcohol in the gas cuts the oil film on the cylinder wall and there goes your lubrication. Seize up will shortly follow.
In my state (Minnesota) the hot rod and motorcycle lobby persuaded the powers that be to allow the sale of non-ethanol fuel for there older engines and it can also be used in small engines that can't tolerate the alcohol. Perhaps your state has the same program.
Good Luck!
harleyron74.
Harleyton 74
Hi i live in Mn in the southwestern corner and some of the smaller towns don't have gas without alcohol there gas i know this is because i don't use gas with alcohol in the gas in my cars because it get better mileage without it.And i don't use it in my small engines too.I have to go to Iowa to get reg gas with out alcohol in it.:tongue:
