Engine ID of riding mower Yazoo YR30 Red rider
RRGuyATSF
Hello ALL.
I just got a Yazoo YR30 Red Rider in sad shape. It WAS running. It has an 11hp 400cc "Industrial Commercial cast iron bore" Briggs & Stratton motor. The Plastic pull start pulley on top
has the teeth worn out AND it needs a new starter. I can't find ANY motor id numbers so I can't check on parts. ALL help would be gratefully appreciated. Thanks.
Paul in FL (watching the grass grow WAY TOO LONG)
Fish
Look closely on the top cover, usually just above the spark plug., sometimes on the side. Etched into the metal.
RRGuyATSF
Thank You.
