Hi I'm wanting to know if this engine121s02-2015 has a tapered shaft at the end of the flywheel is so what is the dimension of the tapered shaft. I would like to switch out the flywheel on the 121s02-2015 with an existing flywheel that is a heavier gauge . T
thanks in advance Respectfully Chops.
#2
Boudreaux In Eunice La.
Hey Chops sorry I just seen your PM Yes all of them have the tapered shaft at the flywheel. Yes it will fit your new engine ~!~!
