Electrical problem starter won't engage even when jumped/hotwired
eek
  • / Electrical problem starter won't engage even when jumped/hotwired
I have a 12yo Ryobi brand MTD made riding mower with 17.5 B&S engine 31c707 type 0154. Have tried bypassing the solenoid jumping starter direct from positive terminal with no response, just replaced the starter and still can't get any response from the starter at all. Have tried jumping from car battery and straight to starter also with no response. I know just enough about electrical and small engines to get into trouble. Something is preventing the starter motor from engaging. I heard a very faint click a couple of times on an initial connection but nothing consistent, usually I just get no response at all, no sparking, no clicks, nothing. Multimeter shows 12v going to the starter. There must be an electrical issue I'm missing, but what?
Bod
Are you using both the POS and NEG connections when you try to jump the starter? I suspect a ground prob.
eek
Thought of that last night, will try again today and update.
Go through this troubleshooting procedure and give us the results. Should be able to point you in the right direction.
Electrical problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
eek
Thanks for the replies! I had basically done all the steps listed above except for 6. So I finally determined that when I grounded jumper cables back to the engine block, the starter engaged. Then I followed the ground from neg. terminal to it's connection to chassis, disconnected, and cleaned off the rust/corrosion/etc. Now it starts stronger than ever. I've never really worked on vehicle electric, but the principle of completing the circuit still applies...
Glad we could help.
