Welcome to the forum...
What engine is on it?
AND more important is the flywheel equipped for a starter? also are there mounting points on the engine for the starter? :smile:KennyV
as Kenny said,if you got mounting points on your engine,also you proably will have to put a flywheel with a ring grear on it.I converted a pull start to elec. start on my JD111 but was lucky in having a wrecked B.&S. that had the f/w with the ring gear.not sure what the cost would be for you to do this unless you can find a used one somewhere.first I'd check to see if you have the mounting points for the starter. russ
