Echo weedeater/brush cutter?
bassadict69
My old Craftsman weedeater/brush cutter bit the dust last summer so I am needing a new one and looked at Echo the other day.
I am needing one I can change the head from the string to a brush cutter blade for use out on the deer lease. I am looking at the SRM 266T...Any opionions on this?
You'd be better off with the FS 110 Stihl. You may want to also look at the FS 90 Stihl.
Thanks Ric, I will look into them...
The FS 90 is a solid, straight driveshaft works with a variety of cutting attachments giving you more flexibility in trimming applications. Plus it has a somewhat bigger engine at 28.4cc vs the 25 cc Echo. and there the same price. The 266T weighs 13.6 and the Stihl FS 90 is 11.7 which is a big difference when using the machine over an extended period of time.
Due to warranty and other little things they explained, I went with a Echo 266... Thanks everyone for the help!
I think yull be happy with it. Now I only use stihls. But I still have my echo 225 brush cutter from 2 years ago, and it still works great!
