Eaton 850 Hydro, Used on Ferris and a few others
jesse777
I need the right (as you sit on the machine) axle shaft housing for an Eaton 850 transaxle. The mower is an older 3 wheel Ferris rider. This trans was also used on the Snapper GX2000, Deutz-Allis 1800 Series (1816H) Sigma, Simplicity 5200 and probably more.
I'll need used as new is way overpriced on this discontinued transaxle.
Drock5400
I have a used one they main pump is out the cam ring broke ill ship you the whole thing if you haven found any used parts came off a Duetz 1814 with 624 hours
