Dyna Mow ZTR mower
Travlitt
I acquired a used Dyna Mow ztr mower and need some help with it.
It is a 5223 C series
Model# C23KAW
SN# 23KAW-102
In original condition
I need the wiring diagram if it exists.
Short history as I know it...was running last summer, electric clutch went out, has sat since then. Safty switches condition unknown.
Need wiring diagram so I can trouble shoot it. Any advise is appreciated.
Thanks
Travis
Model# C23KAW
SN# 23KAW-102
Thanks
Travis
Follow-up on the Dyna mow.. I have it running..2 bad safety switches..they are 4 terminal switches and one side of one switch was bad the other switch was mangled so I replaced it.The electric clutch has a bad fuse link in the control circuit..replaced and now works as it should. I also completed a full service on the engine and the hydraulics. Just need to adjust all linkage. Blades are shot..Hope I can find some replacement blades, no luck so for.The blades for a Husqvarna 2654 have the right pitch and are the right length. I will probably have a machine shop mill out the 5 star center hole and enlarge it to a 1" hole. After that, I will have a super good heavy duty commercial mower. Any thoughts on this approach??
You should be able to go to a toro,scag, or any dealer that sell blades an buy blades with that size hole an length that you need :thumbsup:
