beg
- Aug 7, 2013
- 49
- 244
I have a 10550 and a 10323 both with the plastic carb.I have seen all the youtube videos where this works and that works but my opinion is that the carb body warps and no drilling jets or spring replacing is going to cure that.also after the gaskets have been r and r'ed several times they too will leak air as will the warped carb body causing the surging issue so many refer too with the duraforce engine.I rebuilt the 10550 carb and it runs great but 55.00 is 55.00 bucks. now on the 10323 same thing but it has to run right?you would not think that just one little spring will make it surge and run erracticly all by itself with out a little help from carb body warpage.also you can clean that idle air jet all day and its not going to stop surging.there enough said any comments ?
