Drive belt tension
gmankiew
D125 drive belt tension?
Had new drive belt put on. After one use, the belt is no longer tight enough to drive. Can the belt be tightened by me or do I need to bring it back to Deere?
( drive belt, not deck belt)
No adjustments. But you may have a worn out v-idler. These should replaced anytime the drive belt is replaced. Take it back to JD to have lick their calf back over.
gmankiew
Thanks. I'm taking the deck off now and will replace the idler
