Dan1129 Member Joined Feb 27, 2017 Messages 36 Jun 6, 2017 #1 Drive belt was already off and gone when I got the mower. Needing advice on part number of drive belt. Diagram of routing and any help on how to install it. Thanks in advance! Dan
Boobala Lawn Pro Joined Feb 15, 2015 Messages 7,000 Jun 6, 2017 #2 That is NOT a Murray number .... it's MTD This manual should be what you need to install the belt , .... http://service.mtdproducts.com/Training_Education/770-10579.pdf you can get the belt P/N, by visiting the MTD website and using your model # to get your Operators Manual , the belt Numbers are in there .
