Drive belt comes off
fromeo59
I have a White FST 14 and the mower runs for a while and the drive belt comes off. Any ideas?
Which pulley is it coming off of. That will help narrow down the possible problem areas.
SeniorCitizen
If it's an older unit sometimes a worn idler bracket mounting allows the assembly to flop around and get the idler pulley out of alignment with the end result being a thrown belt.
By drive belt you mean the one that goes to the transmission correct. And the large pulley would be the one on the tranny. If so check the support bracket bolts toward the front of the tranny. If they come out will allow the transmission to rock and throw the belt off.
fromeo59
Thanks so much I will check that out.
