Kennykenny
- Nov 30, 2013
- 97
how old is the blower could be from just general use and not having the compression it used to have. this leaves more un-burnt fuel and oil in the exhaust gasses and will slobber a little.
another thing it could be running a little rich as well if you wanted to lean it out a little. not to the point of getting a lean bog but at the point where you still get good throttle response.
How do I "lean it out a little?"
