RYANS'
- Jun 15, 2022
- 5
- 41
Have a Briggs DOV engine on a Victa. This thing won't start. I've cleaned the carb with ultra sonic cleaner. Replaced spark plug. Re gaped the coil thingy, adjusted valve lash to spec. Replaced air filter. The only time I can get this to start is with a spray of carb cleaner. The mower runs fine. I've checked the flywheel and key, all ok. It seems like there is no fuel being delivered to start the engine? When I spray carb cleaner down the intake, the mower starts and runs fine. But with a normal pull, no go. What could it be?, will have to pay for a technician. I think maybe the float is playing up and not letting fuel through, but why would it run fine once started. Any advice greatly appreciated. Thanks guy, keep tuned.
