Auto Doc's
- Sep 7, 2024
- 21
- 1,845
Hello Folks,
The first thing people think when they see a governor arm moving back and forth on an engine with a surging problem is the governor needs to be adjusted. Wrong!
It's not the governor causing this problem. The governor is only reacting to a carburetor problem.
For some odd reason people think that they have to mess with a governor adjustment to resolve a surging engine problem.
STOP! Messing with a governor shaft adjustment. You can actually cause worse problems instead of helping the situation.
The governor only has one job and that is to keep the engine from running beyond a safe mechanical limit and blowing itself apart.
An engine surging problem has to do with a possible air leak after the throttle plate, a worn throttle shaft or a bleed air jet passage that has become restricted.
Some governor arms may have multiple holes for the tension spring to fit, that is normal so the appropriate hole can be used to set the top running RPM of the engine.
A portable generator is a good example of this. The generator has to be able to run at 60 Hz for proper "ideal" voltage output here in the U.S. If the generator were used in Canada or some other countries the spring location on the governor arm would have to be changed so the generator would run at 50 Hz.
