I have two HMR1600 one I bought new and one I bought for a back up mower. It has been the best mower I have ever owned. It has the Kohler magnum 16 hp vertical motor and was only made in 1989 as a prerunner to the zero turn mowere as it turns on a 4 inch circle. I have 3351 hours on the one I bought new and only thing I have done on motor is to replace the fuel pump. the mower has the original greaseable spindles that I grease once a month. I mow 2 acres of grass. I did have to replace the drive chains and chain sprockets once and the steering ball joints because they just wore out after many hours. The mower deck is semi commercial and throws the grass out 6 to 8 feet. Thanks Jim
