Export thread
Dixon ZTR 301 replacing 9 tooth sprocket
#1
T
tulmer52
The 9 tooth sprocket on one of the drive chains at the cones stripped. How do i get the sprocket off? What parts need to be removed to get it off the shaft? I've loosened everything I can think of (except the cone assembly) and still can't find a way to remove it.
#2
T
tulmer52
Well, I finally got it off after removing the transaxle and placing it on my workbench where I could see all the bolts.
