Does anyone have the rubber spring pre-load adjustment dimension for a post 1999 Dixon 3304? The distance from top washer to bottom washer. I have the L shaped adjustment tool, but I don't have the other U shaped one.
Thanks
Thanks for the reply Mark. The PDF only says to use the gauge to set the pre-load, which I don't have for post 1999. I was hoping someone that had one might put a measuring tape or some calipers no it.
