Blades Dixon Speedztr blade won't engage--has part of wiring harness disconnected
kraines
  • / Dixon Speedztr blade won't engage--has part of wiring harness disconnected
I hit a baseball that knocked the blade belt off and in the process of getting it back on, I think I may have knocked these wires loose.
I can't find any wiring info to figure this out.
the wires inside that yellow cover most like go to the electric pto clutch. Make sure that is were they go. If so it doesn't matter what wire hooks to which wire.
kraines
Yes, That appears to be it. However, I can't get to it to reattatch the wires. Off to the shop.
THanks for the reply.
