Dixon Ram Mag 50 Hydraulic Fluid change
kswaywardson
I have a Dixon Ram Mag 50 with Kawasaki engine FH601V. Not sure if it is the 2007(968999561) or 2008 (968999562) model, but I believe schematics are interchangeable.
I am having a bit of trouble locating the Hydro Gear fluid reservoir, filters, plugs, etc. necessary for the maintenance of the mower. I have looked at the manual but am still unsure of what I need to do to locate everything. Are there plates, brackets, other things that need to be removed? Relatively straight forward process? Thank you.
