will a dixon 5501 bearing assembly for the mower deck blades interchange with a dixon 424
E erm Forum Newbie Joined May 31, 2013 Threads 1 Messages 1 May 31, 2013 / dixon bearing assembly #1 will a dixon 5501 bearing assembly for the mower deck blades interchange with a dixon 424
M motoman Lawn Addict Joined Aug 11, 2011 Threads 67 Messages 2,582 Jun 1, 2013 / dixon bearing assembly #2 erm, Try some online vendors. If you have the bearing out and it is not a special sometimes you can call a bearing house and specify the metric dimensions , OD, ID, width, bearing style. Just a long shot since no one else has responded.
