Dixon 30" ZTR battery
titleman
One of my battery terminals needed cleaned today which I unhooked from the battery and cleaned both the terminal and the cable.
After I had hooked it back up and mowed a few minutes I raised the seat and found a small wire/cable that wasn't hooked up to anything. It appeared to have a fuze or something like that in the middle and one end was black and connected to the negative side of my battery and the other end was red and just lying on the battery.
I guessed it need to be attached to the positive side of the battery which I done and everything seems ok. Anyone know what this is or why it's there?
tx
kunzmower
At one time dixon was putting the wires for a maintenance charger on the battery , but it did not come with the charger .
