Mower is dry, grass is dry, hasn't rained in several days. Even mowing in the heat of the day, bright and sunny out and it still clogs. What the hell is going on here? It's starting to piss me off.
Engine running fine? Bag cleaned up? the bag has poures that need to be cleaned regularly to help with the "vacumn effect".
Otherwise are you cutting to long of grass to thick if so you might want to raise it up and cut it twice
Engine runs smooth and it has no bag. Side discharge. The grass isn't even long either.
Ok then I would look at the blade type and I would consider getting a highlift blade.
It's a normal blade, sharpened it over the winter.
Not to look like an idiot but what does a high lift blade do (besides cut grass)?
