Dirty air filter on a JD 425 aws Lawn tractor
plowpilot
Is there a way to reroute the air intake so that it doesn't take so much DIRT?
reynoldston
Maybe add a air cleaner air intake snorkel might help.
plowpilot
Have turned the air intake away from side of tractor , toward the top of engine.
Catherine
LawnWorld Support
Welcome to the forum! :welcome:
I'm going to move your thread over to the JD section to see if we can get you some more answers.
Retiredcarguy
Plowpilot,
The air intake is surrounded by a huge amount flying dust, dirt and debris. JD usually has the engine air intakes placed near the "cleanest area" of the engine compartment, sometimes toward the operator and instrument panel. Depending on the model it may vary. Some models have the engine intake "prescreened" near and by external cowling, screens and grills that are easy to see and clean by the operator.
Like many of us, you cut grass only when you can and it may be very dusty and dry. Rerouting may help towards a somewhat "cleaner area" of the engine compartment. Be careful to never block it or prevent easy cleaning as it needs an open area to pull air from.
