deere wont move
mechanic mark
Drive belt & idler pulleys in good shape? Engine off, pull out rod backside of tractor & see if you can push tractor forward & back, will it move?
Rokon
That is the area I thought of. Maybe someone pulled it out and the owner was unaware of the action. (nasty trick to play on your friends)
