deck level 400s triple deck
daybris
my deck was in a moment about ten millimeters different in level on one side.
is there a video on how to adjust it?
i cannot see anything broken and the deck is now on the highest level but still cuts very low.
and the front of the deck is also very low when lifted up.
i drive ruffly and on many uneven surfaces and i have had problems with the level from the beginnig.
the level is on like 4 inches and the grass still cuts very low.
really need help with this because the seller is such a dumbass and he talks to much about other stuff instead of solveng the problem.
regards from sweden :)
GetTechnicalWithJd
Hi daybris,
You can downlaod the 400s Dealer Setup via the link below.
https://we.tl/t-uuIaZWvR0y
The leveling procedure is on page 7. Don't forget to set tyre pressure first.
daybris
thank you :)
i will have a look at it at once
bye from sweden :)
daybris
found the problem but it took a while to see :)
the left front wheel has 2 bushings on the center bolt a one of them is demolished.
GetTechnicalWithJd
Good to hear. Thanks to the update and happy mowing!
