Dead Electrical System on LT2000
Str8Shooter
Let me begin by saying that I am new to this forum. This is my first post. Based on what I have read in other posts, the people here are very knowledgable. I am looking forward to learning from you.
I have a 2008 LT2000. New battery. The electrical system is DEAD. The fuse is not blown. Turn the key and nothing happens. No noise, nothing. Put new bulbs in headlights just to make sure they were good and even they don't work.
Could it be the key switch or is it likely something else?
Thanks in advance for your help!
Shoot straight,
Sr8Shooter
timtractor
I would start with looking at the two cables that connect to the battery.
Make sure that where they connect to have clean connections at the battery and at the other ends where they ground and connect to the solenoid.
