DC 2760HP - Engine Starts ok but dies after Disengaging Brake
RWM54
Engine will die after disengaging Brake. Have checked two seat switches, neutral switches. I can start the engine, then remove the kill relay, and can disengage brake without the engine dying. Any feedback on wires from kill relay (where they go, etc.) that I should test, trace or check for problems.
